Auxilery Fan
Right Engine is prtty much ready to go back in this week, im just tidying up the last of the engine bay, But just wondering, When I deleted my Aircon and and removed the ac rad etc I left the Aux fan in place, is it worth removing or can I wiring this up for extra cooling for the rad?? not that I should need it.
What do you guys think or had anyone else had probs caused by removing this??
Cheers Craig
it is there for extra cooling anyway ive left mine in after deleting the air con
It cuts in at around 104c as Emergency cooling, but If it ever gets this hot then you have a serious cooling problem and the car is already at risk of headgasket failure or worse.
I have removed mine, but you must have an accurate aftermarket temp gauge that will warn you of overheating issues before they get that bad, preferably with a visual and audible warning feature. Removing it does improve flow to the Main radiator and engine bay.
Edited by Yowser
Think ill keep in it then, just incase
Thanks for the info guys
Craig
