350z brake upgrade
looking to upgrade the brakes to 350z discs, but cant find anywhere that does the brackets for it, il be keeping the 300zx calipers just upgrading the discs to 320mill off the 350zx, does anybody know a place that sells the brackets and has anybody done this and what the results like also can i do the same with the rears
  • Replies 46
  • Views 3.5k
It would be easier and cheaper going the skyline GTR33-34 route.
Same size discs at 324mm, the brackets are easily available, well they used to be, loads of options for different brand discs.
350Z brackets are usually only sourced from the US, not many options for discs and they are also 324mm not 320mm, yes you can fit the rears but involves a lot of work, only know 1 guy here who's done it, search and you will see what he had to do.
hth
smithy
cheers the only reason iam looking at this upgrade is cause i just bought yellow stuff pads for the car and wasnt really happy with the brakes still, i came across a 350z in the scrapyard 2day good discs and can get them cheap, so would they be much of an improvement, wouldnt have the funds for a gtr setup at the moment
Ignore me, thought you was on about calipers
Edited by murt
you will find if you overhaul the calipers front and rear and use DS2500 ferrodo pads or similar the stopping power is really very very good and a much cheaper option than bigger discs and all the buggering about thats involved in it......
Right okay, if the car in the scrappie has Brembo calipers on the brakes, then take them and the discs and fit them, no brackets needed.
The above are 324mm sized discs
If it has standard Nissan calipers it really ain't worth the grief as they only 296mm sized discs and you'll have to get brackets made up to suit, not a simple cheap job tbh.
In short though, larger sized disc with standard calipers can be an improvement, however 324mm is the largest i would go personally with brackets.
hth
Smithy
Ive done the 350z rears and its evem more hassel if your fitting the 350z rear discs
hth
Smithy
the discs defo are 324mm x 30mm but the calipers are silver, i thought the brembo calipers are gold, iam not to sure now if there are brembo or not i found these brackets would these do?http://cgi.ebay.com/ebaymotors/240sx-12-75-big-brake-upgrade-300zx-calipers-brackets-_W0QQcmdZViewItemQQhashZitem5199a8eca1QQitemZ350470335649QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Mine look like this.....
http://cgi.ebay.com/ebaymotors/300ZX-Z32-30MM-BRAKE-BRACKET-ADAPTER-12-75-350Z-ROTOR-/200522942100?pt=Motors_Car_Truck_Parts_Accessories&hash=item2eb0194694
These are the relocation brackets you need for keeping the standard 300zx z32 caliper and replacing the standard 300zx z32 disc/rotor with 350z brembo fitment discs/rotors, and of course new pads of your choice.
HTH buddy,
Alz.
Edited by AlanZ
cheers yea they look like the right job, does anybody have a pic of what the brembo calipers look like cause iam thinking the ones in the scrapyard are cause the discs are defo 324mm x 30mm and are the brembo a direct fit front and back
Much better to buy the Calipers and Discs. They are substantially larger calipers than the stock Z items, and you dont have to go about getting brackets as they just bolt straight on.
Forget about fitting the rears though.
Edited by Yowser
do the rears not bolt on no?
no, you would have to either look into a relocation bracket, or do what others have done which is to cut and reweld the mounting points on the hub.
Evo Brembo calipers are Soooooo much bigger......like mine.... :winkiss:
Alz.
which evo are they off and were they hard to fit, :no: dont know what way to go now
Alz.
yeh, but their not big compared to my AP racing setup :p , and he's got access to a 350z breaking.
Alan is right though, the EVO setup is a great brake upgrade option in terms of size and cost, if you dont mind getting some brackets fabricated. The calipers are available very cheap as they are not as well known about as the GTR/350z brembo's.
There are plans out there for the brackets, Alan probably has a copy ?
Edited by Yowser
Evo V and higher....
My set up (still to fit.... :crying:) is Evo VIII calipers, Evo EBC yellow pads, relocation brackets and 12.8 tensile bolts, 350 Brembo discs and Evo brake lines are a direct fit.
Alz.
And there's me thinking that it does not matter about the size of the caliper.......mmmmmm, Where did I hear that before..... :huh:
Biggest name in braking........
Brembo or AP.......
Alz.
For Stopping distance - no ....for heat dissipation and fade resistance - definatly, yes ;)
Edited by Yowser
So Brembo is better then.............
Brembo are a popular Standard manufacturer fitment, and make a very large range of Calipers.
AP Racing are the big name in Racing.
Edited by Yowser
are u putting them on front and back
No matey, only front. The caliper size will not affect the braking distribution from front to back. Some people that fit BIG front calipers..... have had issues with this.
Alz.
can i upgrade the brake fluid 2 and what dot would be the best to go 4?
