Power steering pipes diameter
Quick one folks just so i dont have to drain my PS system what is the internal diameter of the PS pipes on a NA pot the 2 that come off the pot? Im looking at moving the pot so hopefully someone has the pipes off that they could measure or a pot lying about that they could measure for me
cheers
Marty
you mean the resivoir feed, tahst about 22mm i think. if your really desperate to know exactly il get the vernier out on the hose i have left.
yeah its the 2 off the pot i need as im going to fit longer pipes so need to get the right ones a measurement would be good thanks :)
right internal diameters of the pipe i used are, 10mm and 19mm i also used a 21mm 90 degree joiner and the 19mm slides onto this without too much brute force.
have you relocated it to by the brake master cylinder too? i think i know what you mean by using the 90 degree joiner if in this position the large pipe is gonna foul on the bottom
no they were degraged and falling apart, i replace them when i overhauled that powersteering fluid lines etc. sadly nissan no longer sell the resivoir feed pipe or the hicas return.
