So, a little after 6 weeks of having my car back I think its developing another wallet busting mechanical issue :helpsmilie:
I'm hearing too much from the gearbox recently. Particularly 2nd and 4th gear, which I'm guessing means there's a bearing going on that shaft? When I take it past 5 thou rpm in either of those gears i'm hearing a vibration/rattling noise which also transfers to the gear knob?
I was hoping it might just be in need of an oil change ('box oil) so I've booked it in at Zedworld next week. But after two spirited driving sessions yesterday I'm pretty convinced it's shagged. It also seems to be getting more prominant.
I know the synchros on the pre '98 cars are prone to failure, but it doesn't seem to be synchro related, the shift is still sweet enough and not difficult to engage - its once once the gear is home that the noise starts. Has anyone else had problems similiar to this?
Also at low revs in high gears (4th & 5th), it sounds like there's a lot of slack, not excessive vibration but pretty noticeable.
Finally - what are the options gearbox wise? A new '98 spec box is gonna set me back in the region of 1500-1750 imported and fitted. But I'd rather upgrade to a 6 speed box if it does need replacing. Yowser was on about the Borg-Warner box from the Camaro - has anyone done this conversion previously? I imagine its generally a ball ache process trying to sort the bell housing and prop shaft? What other options are there? Is it possible to rebuild the existing box?
Damn these bloody Zed cars with their swiss cheese mechanicals :crying:
