Has anyone fitted Stillen anti roll bars to the Zed?
I tried fitting the Front today but finally realized after messing around for ages that its impossible to bolt the brackets with the poly bush to the chassis. On the chassis leg where you are ment to bolt the bracket there is a lump that i guess is to align the standard mount. On the Stillen poly bush it doesnt alloy for this.
What have you guys done?
Thanks Dan
Ive got pics if needed.
Edited by GIBSTER-TT
added pics
Need some pics bud, I did'nt have any trouble fitting my whiteline ones and can't be that much different.........or can they?
Ive seen this before and they used spacers ( square) either side of the bush/lump to even out the load when bolts are tightened, so it then sits flat to the front frame.
Sorry bud mine wasn't like that, the part that it's being bolted to was flat. Jap TT & UK TT
I thought of this too but i dont think the bolts will be long enough.
Ill have a look again tonight might just grind the lump away
Done mine no problems,do make sure you get adjustable drop links on the rear,just don,t get the stillen ones.
What's wrong with the Stillen ones?!! I've just put them on mine!!
Snap I've got stilled rear and powertrix fronts. has everyone used washes to pack out the bump then?
ok i cant see how these anti roll bars can be fitted without fitting spacers and using longer bolts or grinding away the lump. Starting to get to me now i just wanna fit them. Any ideas?
I can't remember there being a lump like that when I did my whiteline roll bars, there wasn't a recess in the bushes either. Is the lump solid metal? It looks like it's been punched.
If it's solid then grind it off, if it's not then I wouldn't grind it in case you end up with a square hole.
It is pressed into the steel if i grind it off i dont think it will be a problem i may have to add washers to keep the bar away from the lip on the chassis. I took the anti roll bars off years ago and not got round to searching though all the spare parts to find the OEM bracket yet :( Stillen dont seen to have an online pdf instructions either like some manufactures do. Pain io n the arse lol
mine went straight on :wack:
Same as ^^^^ (Stillen front and rear ARB's on UK spec LWB), using Whiteline and CZP droplinks
planning on fitting them on the SWB shortly
Sorry what i should of said is ,don't buy them separate because they cost a fortune .But other wise there fine
What am i doing wrong then? Did any of you have the lump in between the bolts?
no mate sits nice and flush :wacko:
