Strange issue.....
Strange thing I have noticed on the car since I purchased it.
When I change up at above 4.5k rpm I can feel like a sort of vibration through the clutch pedal, only happens when you depress clutch and engine braking starts, once you engage another gear it instantly goes away.
Also if you don't press the clutch and select another gear then the vibration can still be felt until it drops below 4.5k rpm.
I've probably not described it very well, but it is a kind of strange issue, I'm wondering if it has something to do with the auto to manual conversion, as my previous manual TT Zed did not do this.
Under normal driving and below 4.5k rpm there is nothing at all untoward.
Any advice will be greatly received :)
No posts to show
