quick question
a bit OCD but can the glass be removed from the front lights easily?
fitted HID's today and it shows up the dust inside the light unit, need it clean !
There are a couple of metal spring clips holding it on and that black tar stuff - need to heat them up.
I've done a few sets, but I did manage to crack one in half :oops: ...and my hands in the process.
Cleaning the inside of the headlights makes a really big different to the output, they are much dirtier than you think.
excellent, is it a job for the oven? or will a heat gun or hairdryer be ok? also will i need to replace that bloody black stuff
Heat gun is fine mate, it's what I used. Don't forgot that the rubber is held on by 4 metal guards, you'll need to remove these as well :)
Depends, do you want them water tight? lol
the rubber strip around the light? that you see from outside the car? if so then ok cheers, will give it a go tomorrow
supose.... guessing tiger seal or similar wud be fine?
The black stuff will reseal with a bit of heat on it. No need to replace it.
even better :chinese:, cheers
black stuff? my head lights have a light gray substance, its also a lot easier to get apart than the rear lights, you don't need to heat it as much.
Do all your headlight beam adjusters work, good time to check the cogs are not fooooked when you have them out :cool3:
didnt even know a had em.... is there a downloadable workshop manual anywere?
Once you've removed the glass from the front of the headlight the dishwasher actually cleans it really well ;)
In the faq section :mellow:http://www.300zx.co.uk/cgi-bin/manual.cgi
