Miss Fire bad running Please help
Ok New engine after it blowing up
Check all timing and all aligns up
0 on crank and all cam Markers on the back plate align
New injectors
New Injector plugs
New Plugs
tryed 2 lots of coil packs
even my old injectors
when i can get the engine running its sounds nice ( engine )
no knock/bangs/taps
Oil Pressure is right about middle on ide>2k
the engine will not go past 3k as it dies out
the miss fire is mainly on the passenger side bank
does any one know where the wires normaly brake or
know of a good Loom thay no longer need
Please help
  • Replies 80
  • Views 3.1k
This might sound stupid, but have you cleaned the battery terminals and the wires coming off it? Mine were all oxidized and gunked up so a quick wire brush and clean made the world of difference. I tried the maf and the ptu etc and she still had an intermittent fault, but since i cleaned up the battery, she's been good as gold.
check out this link... there are loads of things to try for hesitation/misfire/etc
http://www.zhome.com/ZCMnL/PICS/hesi...esitation.html
ok just been out checked the connections and even jigged up an extra earth ..
still the same
I had a similar problem, well still do actually, but to cure the problem on mine I unplugged both O2 sensors, runs fine with them disconnected, as soon as I reconnect them I get all sorts of mis fires and bad running, gotta be worth a try mate!
all brand new pipes on the boost side and 80% of the vac pipes have been replaced ..
do need to do a vac test
i have had 3 lots of sparkys
i now have brand new Coil pack connectors
Brand New PTU and Connectors
Brand New Injectors and Connectors
i have the right connections as all was Numbered up
the Nock and O2 sensors are diffrent plugs 2>3pin
It may have been o2 and coil pack,
know couple of them were similliar.
If you numbered them should b all good..
These cars are never straight forward i only puy my engine in couple weeks ago,
The cambelt went on my old engine the little pulley between all the cams pulled the thread out from where its bolted.
The new engine had what looked like a new waterpump on it which collapsed within 2days.
So i put another used pump from my old engine and a couple days later its gone again. the viscous dont seem right compared to my old one, seems to have movement which i think is knocking the pumps out. thought i may b tightening the belt up to tight so 2nd pump left it more loose and gone again,
Bet when u find it its something silly, giving you loads of problems.
But your forgive it for all the trouble it causes soon as u drive it again.
I allways do lol.
goodluck.
just spoken to Zedworld ..
hes said by what i have done it could be the ECU ?
what u guys think
is it because your using 555 injectors without a 555 chip????
Would have thought the 555s would just sit there half used without another ECU, wouldn't expect running problems. That being said, the ECU could well be the problem. at the end of the day, if everything else is working/replaced and tested, the ECU is the final thing that runs it all, so failing a severely damaged loom, ECU would be a good bet I'd say. I have a series 1 Auto ECU sat on the shelf, nothing better I'm afraid.
lol oh dear i will explain again
Car working fine
engine went bang ..
engine block all my working stuff like inletmanifold/turbos/sensors/pipes
swopped over ..
engine will not start right pop pop bang bang missfire like mad ..
So i have changed
coil packs 2 sets
injectors 3 sets
all coil/inject connectors
spark plugs 3 sets
all with same problem ...
i now have Brand New
555 injectors & TDA55 chip install in to ECU
PTU and Connectors
Brand New Boost and Vac pipes i can say there is 99.9% of no leaks
Still the same problems
the only thing that is left is the Main Wire Loom & ECU
try and put the ECU into test mode, if it doesnt go. its broken.
I'd say swap out the ECU as a test, surely someone can lend you one to try? If that fixes it, see if you can get yours re-mapped or buy a replacement, otherwise, could be the loom. Was the loom known to work before the car blew up?
yeah the car was working fine .. oil pump failed tuck out the engine ..
i re-chipped the ecu but I'm good with elecy stuff as i do it day in day out
but remember the problem was there before touching the ecu to chip it
You do something with the dial that's on it, I'm not entirely sure myself though, there's a guide somewhere on here though. Have a search for ECU Test Mode
cant remember exactly best forum search it, very easy takes 5 mins to do :-)
Yeah I've just stuck a manual ECU in Roses car, which up until last Wednesday was an auto, works perfectly! In addition to that, mine has always been a manual, but it looks like someone stuck an auto engine in it when the last owner blew up the original engine, I've got a manual Mines one in mine and it runs the engine perfectly well :D
that's fine just wasn't sure as per wanted thread didn't know if they was com-pat
oh and how to i tell if mine is a S1 or S2 ECU
If your car is an S2 it should have an S2 ECU, but I should imagine there isn't a lot of difference between ECU's, someone may correct me there though as I'm only guessing.
mark if you want to try an ecu give me a call , im not a million miles away
07929 159828
i know mine is a Late 94 to 95 as its got the Electronic rear steer ...
but thats all i can say
how can you tell ?
Didn't you say you had an S2 PTU? Or was that converted?
