Standard recircs.......
Does anyone know what the limit of the standard recirculation valve is in psi?
Cheerz people,
Alz.
Not in psi but this guy sees it if you are aiming for 600bhp+ http://www.twinturbo.net/nissan/300zx/FAQ/FAQpages/bov.html
This thread implies 12psi http://www.twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=837615&forum=technical&dtSearch=0
and this ones says the modded ones will go to 20 http://www.twinturbo.net/net/viewmsg.aspx?forum=general&msg_id=2268319 but there are technical discussions as to if this ruins the effect of recircs and makes them as bad as BOVs.
well im sure some people are rnning upto 16 psi but i suppose its worth bearing in mind the worn internals. i would say to be 100% sure you could run aftermarket ones.
