New injector loom
I have got two Nissan replacement injector looms, three connectors on each one, but only two wires coming from them, where do they connect to on the old loom, I can't see where they go. Have looked in FAQ with no luck, can someone point me to a fitting guide.
cheers Paul
Hi Paul, the injectors are sequential so need a feed each. You will have to split the loom and terminate each injector pair to the original loom. Ive had to do the same with my spare engine.
Just mark each one with tape and number, 123456, same as the firing order on the coil packs. Solder and heatshrink each pair, the thicker wire on the injector to the red stripe thicker wire on the loom of the new one.
IMO they shouldnt be called a loom, just replacement connectors with some wire on them lol
Graham
Thanks Graham, I only bought this kit because I thought it was a plug and play loom, the description is totally misleading.
Paul
Edited by 300_zedx
Me too lol, but at least you get new connectors and although you have to split the loom back, which is the pain, for me it was easier with the engine on a stand and under the plenum. Although i have the wiring in the engine bay to look forward too :mad2:
Graham have you got any top tips when soldering, should I twist the wires together before applying the solder.
Paul
Hi Mate, Sorry just watching the soaps lol.
Twist together opposing each other so that when they are soldered together you dont get a ridge, otherwise the heatshrink wont slide over. Place the soldering iron under the twisted pair to build up the heat then apply the solder so it flows into both twisted wires, dont dab the soldering iron, keep the heat on till it flows.
Get a heatshrink kit like this http://cgi.ebay.co.uk/127pc-Heat-Shrink-Wire-Wrap-Cable-Sleeving-Tubing-Sets-/280695278660?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item415abe0c44
Place some heatshrink over each pair of wires away from the heat before twisting and soldering and a larger diameter that will cover the pair. So 3 pieces per wire/join.
When soldered slide the smaller diameter pieces of heatshrink over the join and heat, using a cigaretter lighter, once both joins are covered, slide over the larger diameter heatshrink over both and heat again. You should have a nice sealed and isolated join.
Now repeat 5 more times and job done lol
Thats a good deal Howard, i could do with some coil pack connectors a couple of mine have disintergrated and i gave some spares away before i knew it lol
and about a week wait to get them as well
£83 quid for the lot from other link
Edited by MarkDerby
hhmmm
i dont like waiting
and yes i understand i dont like Comp/sellers taking there time over nothing
i carnt do it as i would have a right old ear bashing on the phone from customers
http://cgi.ebay.co.uk/NEW-NISSAN-300ZX-90-94-FUEL-INJECTOR-CONNECTOR-HARNESS-/360369529753?pt=Motors_Car_Truck_Parts_Accessories&hash=item53e7b2a399
These are what I have just bought, took about a week to arrive.Should have read the description properly.lol
You will need a pack of heat shrink, soldering iron, solder, electrical tape and cable ties, you do get 6 cable ties and heat shrink with the kit but you will need more heat shrink as it's not enough.
Paul
Edited by 300_zedx
doesnt matter as your gonna chop the plug and wire to solder in to your loom
each plug would have about 8" of wire to use
Mark
No idea, its how they come, once split there are 3 pairs of wires to splice in, i guess its a way of selling new connectors with a bit of wire on lol
