protoj · Tuesday at 18:48 2 days
Hi there all,
Need to change a rear wheel bearing and been quoted 390 quid! Now I didn't think it would be that much or have I missed something? Anyone reccommend a garage near Basingstoke that wont rip out a kidney to do it.
