aircon confusion r12 r134a
Just fitted 2 new push fit conectors over my old type, tyre valve r12 gas connectors .A bit of gas came out doing this ,air con hasent worked for 2 years so i take it needs a regas .after searching its seems some filling up with the new r134a gas no problems without changing seals etc .Some say it needs other mods to run the new gas diffrent oil, higher running pressure etc.also my air con clutch thing is permantly out what does this mean ,does it do this when its gas low on gas .Is refill point top or bottom connector thanks taff.:thumbup:
