rear washer problem
anybody know which fuse protects the rear washer . ive got no power at the washer pump . just wondering if there is a fuse for this circuit or whether it could be a fault with the mist switch on the pod
Are you getting squirt on the front screen? the pumps are on the same circuit.
Check both rear and front wiper fuses, anything else not working, cig lighter etc.
Failing that, check the terminals on the plugs to the pump motors.
cheers graham . everything else is working . ie wipers and front washer . i think it might be the switch on the pod as theres no power going to the rear pump . im gonna try another unit tomorrow
andy
Try connecting the front washer plug to the rear washer plug and see if the pump is dead, they are next to each other in the water tank, front drivers side.
