where to get resistor for dett sensor bypass
as above, can you let me know where to get one from. doing a dett sensor bypass as i have an EBC. and keep getting code 34's.
maplins probably your best bet
go to any tv spares shop and get a 1megaohm resistor, i picked up 5 for 50p.
I have sent these onto other members, but if you get stuck i have a place very near me.
cheers mate. will try today.
i got some in garage if you pm me your address will stick a couple in the post to you.
dan.:biggrin:
  • 3 years later...
I use 0.25W. I have tons of the things.
Right, cheers for that. I take it I can pop to maplins etc? I may even have one already. I've done away with the dett sensor on the block now.
Forget Maplins, I'd rather send you one for free :wack:
Yeah, whatever.
Just PM your postal address.
While we're in the topic... My car seems to stay in safety it's safety map/boost for the first drive drive of the day, if I cycle the ignition, it runs properly.
Is it only the dett sensor and the temp sensor that can cause it to drop into safety map? I'll be bypassing the dett sensor to rule it out shortly...
I would say before bypassing it needs a consult check,an open circuit det sensor wont cycle usually on the ignition,you may have an issue which needs fixing and not masking with a resistor
