how much does a ZX TT Weigh? and what weighs what?
ive looked around and cant seem to find any sorta official figures on this site.
what sorta things weigh what?
ac?
4 wheel steer?
cruise?
bonnet?
electrics?
  • Replies 47
  • Views 1.5k
There is a thread or page somewhere where a guy has weighed the car and all the parts he's removed/deleted seperately so you can guage where and how to lose weight.
I'll go looking but might take a while lol.
I often wondered if the 1560kgs that is often stated in magazine stats was the actual weight, or the manufacturers 'dry weight. The car could weigh 1560 but factor in a tank of fuel and a few vital fluids and it soon adds up. Ferrari are known for quoting dry weights rather than actual on the road weight.
I think the TT is too heavy really, but I'm not prepared to start stripping things off in the hope of saving a hundred Kgs - I'd rather just make the missus get out and walk!! :whistling:
the a/c system probably weighs about 15kgs all in including the pump.
the hicas system would probably save another 20-25kgs
cruise control doesn't weigh anything really, apart from a switch and a couple of circuit boards
the bonnet weighs about 25kgs - but you will need this! A carbon bonnet will weigh less than 5kg (proper one)
I would recommend keeping the electrics - I've heard pedalling a zed is hard work! Unless you want to remove the eletric motors from the doors and wing mirrors etc. You could also replace the rear windows with plastic ones, remove the spare tyre and carry a can of get-you-home foam. Ditch the tools cos you no longer have the spare. Only half filling the tank with petrol will save an easy 30kgs. Removing the rear interior another 30-40kgs. Chuck the fag lighter away will save you 78gms! When you're driving a bare shell around you'd probably wish you'd just left it the way it was.
Best thing to do is shed 10kgs by taking the targas out and going for a blast to use up some ever-so-heavy petrol!
Stock kerb weights are :
TT Stock Kerb Weights (Manual)
Slicktop - 1510 kg
SWB - 1540 kg
LWB - 1590 kg
NA Stock Kerb Weights (Manual)
Slicktop - 1430kg
SWB - 1460 kg
LWB - 1510 kg
Auto is approx 15kg heavier than Manual
Weight will differ for UK/Jspec (oil coolers..etc) and depending on spec (elec seats..etc)
I have stripped down my slicktop to 1350kg, while retaining Interior and insulation. Thats a good 250kg lighter than the average Zed (or the same as 3 Big blokes)
I have weighed everything I have removed/replaced.
Rounded up to nearest kg.
Front
Aircon removed (Pump, Bracket, Radiator, Condenser, pipes, Fan) – 15kg
EGR removed – 2kg
AIV removed – 3kg
Carbon Canister removed – 3kg
Lightweight Crank pulley fitted – 4 kg
Cruise control removed -1kg
Hicas solenoid and piping Removed – 3kg
NA Pas Pump and Bracket – 3kg
Battery moved to boot – 16kg
Lightweight flywheel – 7kg
SS Turbo elbows and down pipes – 11kg
Fog lights removed – 2kg
70kg loss
Centre
Lightweight seats fitted – 23kg
Lightweight Prop shaft – 7kg
30kg loss
Rear
Spare wheel removed – 15kg
Nissan Tools removed – 2 kg
Tailgate weight removed – 2kg
Spoiler removed – 7 kg
Rear Wiper & Motor removed – 2kg
Cargo blind removed – 2kg
NA Rear subframe & Diff – 35kg
Lightweight Battery fitted in boot + 6kg
Rear speakers – 2kg
60kg loss
160kg total loss
Wheels, Suspension Components and brakes not weighed yet.
An important considering with weigth reduction is to maintain or improve on the stock weight distribution.
Stock bonnet is aluminium and very light - lighter than CF bonnets.
Edited by Yowser
I have stripped down my slicktop to 1350kg, while retaining the Interior. Thats a good 250kg lighter than the average Zed (or the same as 3 Big blokes)
Where am I going wrong, mine now weighs 1422KG and I've nothing left to remove! It's noisy, uncomfortable and has no creature comforts!
Edited by zed-racer
Where am I going wrong, mine now weighs 1423KG and I've nothing left to remove! It's noisy, uncomfortable and has no creature comforts!
Your stretched version started with a 80kg disadvantage :tongue:
I don't stand a chance.......rubbish!:mad2:
Have you considered different wheels ? They are momo one piece cast wheels ? - Weight saving to be had there
Are you runnng TT Rear end (Subframe, diff, hicas..etc?) ?
The cage prob added a further 25-30 'ish kg (its advtanges overshadow its weight though)
There are Carbon fibre and Glassfibre replacements available for the Doors, Targas and Tailgate.
The UAS 300zx LWB Race car is in the low 1200's if you want some ideas, here's its details : http://www.uniqueautosports.com/motor_sports.htm
Edited by Yowser
Does this mean i'll lose 80kg when i convert from auto to manual? Lightweight flywheel too and possibly aluminium prop :tt1:
About 15kg difference between auto and manual
Lw prop and flywheel will shed a further 12-14kg depending on type
Ok, so I'm far from done. I'll just re-mortgage the house and I'll be sorted!
But in the interest of staying married, I'll stick to taking bits off the car for now!
Slicktop - 1510 kg
SWB - 1540 kg
LWB - 1590 kg
Not so my friend!
Don't know if they changed the material for steel in the mid nineties. But given all the tight-arse measures taken to save money (no boost gauge FFS) on the mid nineties model it wouldn't surprise me. My bonnet is steel - not aluminium - I can also tell you it is very heavy! put your fingers on the slam panel and I'll drop it from 20cm if you don't believe me! It is at least 20 kilos, more like 25..
Also, a carbon fibre bonnet IS lighter than aluminium - if they are the same design. If this is not the case, then I will gladly empty all my pockets of fluff and give that to you!
My slicktop weighs in at 1370 kg and that's not dry. It's also not as a result of making a huge effort to remove weight either. But my seats and wheels alone must save 50 or 60 kg. It is bloody noisy though lol.
Not so my friend!
Steel bonnet may be a later model thing, but I think you probably have an aftermarket pattern part bonnet.
You literally need 2 people to remove the stock Aluminium bonnet just to prevent it blowing away :rofl:, its very very light.
All of the aftermarket CF bonnets I have felt on a Z (admittadly only 2) are heavier than the stock Aluminim bonnet, and many others have experienced the same. They tend to have to be made thicker for more rididity- and typically fibreglass frame with a Carbon fibre top made up as a resin wet layup. I think the only one available that may be full CF is the Border hood, but its still not really any lighter.
Edited by Yowser
I can remove a stock bonnet on my own and lift it from one side of the car and clear the vehicle with out straining or worrying about dropping it, it's very light
Excellent,
So this probably means my car has been front-ended at some point! How pleased I am! Anyone else with a '95 spec car felt the weight of their bonnet recently? Or am I the unlucky soul who has the only steel bonnet?
Anyone got an early series aluminium bonnet lying around??
Excellent,
I've got a spare bonnet kicking around.
You sure its Alu though?
Maybe its blown away!! :lol:
Its definately aluminium, it wasn't until your post earlier that I realised you can get a cast iron version! :lol:
