Anyone here from or near salisbury?
My previous owner to my car was A MR Alan Sneddon from SP4 and before that it was a mrs joyce from PO12 Portsmouth,
eg is G449 YDV, didnt get much info when i baught it in may last year, woundred if anyone could help me?,
Started woundering when i took the front bumper etc of a couple weeks ago and found this:
like it had a little bump! but the bumper etc looks mint not apprant evidence of a respray.
When i baught it last year i didnt know too much about these as all i had owned before really was rover 220 coupe's loved em to bits but got fed up of the F*****g things breaking, 3 gearboxes 2 head gaskets etc....
lovely cars tho but not as good as me Z
cheers chris
Shamefully i didint find out about cam belt and its now at 100,000km, currently off road and not using it there much to a 60 k service?
also when on vosa and got all the past MOT info, looks like it was off the road for a while
between 2007-2009?
Registration mark:G449YDVMake/Model:NISSAN / 300 ZXColour:WHITEApproximate date of first use:31/12/1990Type of fuel:Petrol
Date of test:25/10/2006Certificate issued (Pass)
Odometer reading:92,159 MilesTest number:793728096270Test station name:NEW CHELTENHAM GARAGETest station number:79372Test station telephone number:01179674134Test class:IVTest expiry date:24/10/2007Advisory Notice issued
Brake hydraulic reservoir fluid close to minimum level (3.6.G.2b)
Nearside Front Tyre worn close to the legal limit (4.1.E.1)
Rear both Track rod end ball joint has slight play (2.2.B.1f)
N/s/f head lamp cracked
Date of test:13/03/2009Certificate issue refused (Fail)
Odometer reading:92,881 MilesTest number:872922979087Test station name:HANHAM GARAGETest station number:81131Test station telephone number:0117 967 7641Test class:IVReason(s) for refusal to issue Certificate
Nearside Front Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Parking brake Your vehicle has only just met the required park brake efficiency. It would appear that the braking system requires adjustment or repair. (3.7.A.10)
Date of test:13/03/2009Certificate issued (Pass)
Odometer reading:92,881 MilesTest number:174112879495Test station name:HANHAM GARAGETest station number:81131Test station telephone number:0117 967 7641Test class:IVTest expiry date:12/03/2010No Advisory Notice issued
Date of test:25/03/2010Certificate issued (Pass)
Odometer reading:95,920 MilesTest number:912794380029Test station name:RANGERS GARAGETest station number:78078Test station telephone number:01980655555Test class:IVTest expiry date:24/03/2011No Advisory Notice issued
Cant help you history im affraid but nice looking zed really like your wheels! Do you know what they are?
Just found out there off a merc!
I'm sorry I can't help either - but on the surface your car looks like a nice example. And I do like the pearl white!!
As you're kind of in the midlands, I'd suggest getting your car to Jeff and co at Zedworld for a thorough going over.
Since it's 20 years old now, you'd have to expect some paint/body repairs etc at some point in its life. But if you're worried then at least Jeff will give your car a proper appraisal.
Richard:chef:
Will he do a check over then? also does anyone know how much would it be?
you are quite an interesting one CBVD. who 'just' takes off their front bumper.
I have simliar, but quite happy to accept, crunched front left. causes me no more concern than really minor pressure to keep it from steering left.
The Jeff thing seems to be a fave on this forum. He does the cambelt with the check. If you are car enthusiatic, lets say, you dont need that journey.
Drive it around. Breathe. use your ears. accept RWD is not like FWD. your turbo's will act like every turbo in history. Read. do what you can. dont do what you can't.
