Sneak preview .... lol
Dropped the front together just to see what it looks like , me like !!
The trouble is now i don,t want to go and spoil it by putting a number plate on it ! might have to look at one of those number plate hiding things :innocent::yes:
One pic? oooh you tease:lol::lol: would like a closer look at the wing mirror indicators :yes:
The more I see quality builds like this, the more aftermarket bumpers are growing on me!
That looks proper bad, innit..
OK just for you Graham , lol
They,re just a pair of the ones that you,re suposed to stick on the outside of the mirror which looks 5hit so i cut a hole and used a hot melt glue gun to stick them on the inside and now they,re painted i,ve sealed them with a bit of sikaflex . :wink:
Got something like that to do on mine, but they wrap around the corner of the mirror housing. Yours look good.
Paul
Edited by 300_zedx
Lovely mate, really nice and i like the little touch of doing the mirror base the same colour as the back plate, looks neater than trying to mask around the bugger lol
So a quick question, even though the paint has been baked, how long is best to leave it before mopping? My guy is going to just 2k it without a clear.
Graham
Graham
I didn,t bake it bud painted it on a saturday morning and monday was the bank holiday so i new it had a good few days to air dry , went in on the tuesday flatted it using a block with 1500 wet n dry then used some 3000 DA pads on a palm sander DA with some soapy water to flat back to a smoother finish then hit it with a polisher , came up really well .
I,ve never used the 3000 DA discs before , back in my day it was 1200 wet n dry and that was it ! but these discs are brilliant , makes polishing it sooo much easier .
I,m gonna run the polisher over it again when it,s all done as it,s bound to have settled a bit by then .
Mop it as early as you can as it,s easier then lightly re-do it later once fully cured , there,s nowt worse than trying to flat and polish paint that,s fully cured , it,s like trying to polish granite !! HTH
Looks stunning, I'm looking forward to seeing the finished rebuild
So am I..................:wheelchair::whistling::tt2:
Cheers for the advice, i guess mixing the paint and clear yourself with the right amount of hardner will cure quicker than a rattle can ever would.
