Air Con Recharge valve?
they are tucked down the inner wing just in front of the battery area IIRC :)
a recharge canister is really only any good if the AC is working but is low on gas - if the AC is not cooling at all & it is out of gas then the system needs to be vacuumed first prior to charging with gas :)
Hmm, I turned the temp down all the way then switched to 'Auto' followed by Economy and both were around the same temperature, if not the same. Though actually a lot colder than I expected as its been a fairly warm day.
So I think I need a whole re-gassing.
