Anyone have trouble with conzult and windows 7?
Ive downloaded the shareware version of conzult.
Got my conzult unit
Got my serial to USB adapter.
But when i plug it all in and select engine check. The conzult unit flashes but the i get win error code 2 (cannot find drivers)
The CD i got with the unit had lots of drivers stuff on it so i installed them all but nothing seemed to help. Most of it said no need as you have windows 7.
How do you guys deal with this?
Mark
you'll first have to install the drivers for the USB adapter and get windows to be able to access the vcp (virtual comport) that is created by the USB adapter's driver.
You will have to leave the USB adapter connected before starting the conzult software (only the case with laptops that only have USB ports and don't have a onboard serial port)
Once the driver for the USB adapter is installed correctly and the VCP is active (USB adapter connected to laptop) the conzult should work fine.
Thanks. Ill try that.
Although it seems to be that it cant find the drivers online, on the disk or on the computer.
