filling the gearbox with new oil???
With a syringne type hand pump and about 1.5 metre tube attached ,suck up oil and pump into box untill it over flows from fill plug on the side of box.Use half inch breaker bar or rachcet to undo filler plug should be 3.4 litres i think.
It's an auto box mate. No filler plug I think? and it says 8.7 litres?
Funnel in the dip stick tube and keep checking the dipstick after letting the fluid run down and settle.
Unless you have completly drained the system, you will only need about 4ltrs.
Paul
There was a link to a how to only the other week. Sorry on phone at moment so can't help much. A few autobox searches should see you straight. It says 8.7 liters as it's a full fill from empty. When draining you don't get the fluid out if the torque converter so only about 3-4 liters ate drained out of the box sump
