propshaft question [gearbox fitting]
Do i need to unbolt the prop thurther back to get it to fit in the back of the gearbox .I only undone the centre 2 17mm bolts to get it out but it was a struggle to pull out of box its a swb thanks.
Ive also removed the 6 x allen bolts and holders on the diff end.
Mark where the holders were with tippex, 1,2,3, and the same with the bolts, i got a piece of card board and put bolts through in order 1-6.
With the centre 2 x 17mm out aswell. just a case of dropping diff end, and it should slide out.
