Knock sensor
The cheapest one ive ever seen:wink:http://cgi.ebay.co.uk/Knock-Sensor-NISSAN-200SX-SE-R-240SX-300ZX-ALTIMA-/280650881392?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4158189970
Same block, just different internals. The knock sensor is just a peizo (microphine) which senses knocking in the block, so i dont see why it wont work as it should.
Hi Graham, can a knock sensor be tested to see if it's working?
cheers Paul
Hi Paul, On conzult is the sure way to see if its working, as it transmits through the ECU which can be read. If the knock sensor is out of the car it can be tested. Most problems with the knock sensor is down to the loom to the ECU.
