why is paasenger door not locking on central locking and windows slow
while i have the door cards off, (planning on putting back together tomorrow) i wonder why my passenger door is not locking on the central locking? and why my windows are slow going up and down, im crap wit electrical stuff i have absolutley no idea, if anyone can help with a few pointers that would be great, many thanks:rockon:
Check that the solenoid is working, when you press the button and have you got enough juice in your battery, window motor might be struggling with lack of power
yes mate battery is excellent, have you got any spare door locks with keys also?
No Mate, i dont, infact i dont even use my door locks with a key, just the fob key.
You might have a problem with the power window amp in the door, how does the frivers window seem.
oh now i am just so so jealous, i really really relly really want remote central locking i really do, its aftermarket kit i take it,
thanks for the diagram mate i will use that tommoro
I've got a clifford alarm that came off a Z, ends on ebay tomorrow if you're interested?
Does both windows move at the same speed ?
I would check the voltage of the current getting to them, even disconnect
one of them and try a separate power source and see if the move any faster.
You should have solenoids in the door as standard for the central locking, but yes mine are triggered from the fob with the alarm.
yeah i have central locking, did you fit the alarm and remote central yourself?
No the Toad alarm was already fitted when i got the car.
An idea for the pass door not locking, check the bottom left fuse, is your interior light on when you open the door?
yeah ok mate thats cool i have a volt meter so thats a good way, i think i can manage that bit lol
will be back on tommorow after iv tested a few more bits
got to the bottom of it but not sure how to fix it,
the central locking is working fine but the only reason the passenger door is not locking is the catch is not moving over enough, its moving but needs to move a very small amount more to lock, you can see the difference in the catch moving on the central locking to moving the lock catch on the door, just needs to move over a tad more, it doesnt feel sticky although i will try wd40 later unless i get better advise, thanks
can you bend a rod or something to make it pull tighter?
Dont want to state the obvious here but it sounds like a bit of lubrication is needed on all moving parts. Electrics seem to be working.
yep your right it was :thumbup1:
