In memory of Mandy
z32bolt datalog
anybody see anything iffy? seemed ok to me apart from a little high idle (possible idle speed controller needs cleaning)
ecu fault code check clear at 55
Edited by hellraiser
Dam that water temp is high! Mine stays around 75 even after a good clearing out of the system.
that was after a drive. thought that was reasonable for a tt??
my na runs between 79-81 deg 81 is after a hard drive.
Yours is on the cold side mate, generally temps range 78-82, anywhere in the middle is great.
He's a tad hot, but only just!
Smithy
any specic reasons why it might be a touch hot? coolant system need a giood flush out maybe?
