manual conversion check list
after a brilliant night with hellraiser and z32bolt talking about various different things and about manual conversions i was just wandering if someone could post up a check list of exactly what i would need to do the conversion please cheers :)
lol im actually gonan create a boolk to stick all these things in to create a bible lol.
Gearbox
Clutch
Flywheel
Clutch bolts
Flywheel bolts
Front prop half
2x Bellhousing Plates
Gearshifter support bracket
Gear shifter
2x rubber Gearshift gaitors
1x Leather gearshift gaitor
Clutch Pedal box, with Booster if TT
Brake pedal box (or cut your existing brake pedal)
Clutch Master cylinder
Clutch Slave cylinder
Clutch hydraulic pipework - or custom 1m Braided hose with M10 fittings
Spigot Bushing - new
Thats from my dodgy memory though, its been a while since I did any conversions, somebody may be able to post a "how to" guide with a list to confirm I've got it all...or confirm if I have forgotten anything.
Edited by Yowser
adding to list bits I've forgotten
manual gearbox
manual pedal box (tt to include booster and vac lines)
clutch kit
flywheel
spigot bush
flywheel bolts
clutch bolts
manual gear leaver
gaitor
front section of manual prop
manual gearbox speed sensor (should come with gearbox)
from there my mind is blank
Gearbox
Clutch
Flywheel
Clutch bolts
Flywheel bolts
Front prop half
Is there 2 bellhousing plates then? I only have the one.
^^^ah yes, spigot bush. You'll need to get a new one of them from Nissan or MJP, rather than use old one.
Quite oftem I've seen kits arrive with flywheel and clutch bolts missing. These can be very expensive to source. About £90 for a full set of flywheel bolts for example.
£90 for flywheel bolts!!!!!! ouch!
Cant remember for sure. I may be mixing up the Auto and Manual there.......somebody else will remember and reply ?
I'll correct/add to my list if anybody else can confirm bits.
Edited by Yowser
cheers for the comments so far guys now to do some sourcing to see a rough price lol
anywhere between £450 and £600 for the parts s/h mate.
oh yeh phil, after our red light bingo conversation. i put 15 quid in and it didnt even hit quater of a tank lol about half way between.
i just bunged 30 quid in mine, but did have a detour round christchurch!
i did noticve you wenet in the mirror assumed you were dordling lol
i do drive a na :thumbup:
haha mine came on just as i pulled out of the car park so i will need too fill up in the morning o the joy of petrol prices
