Ive just changed the left 02 sensor and today i get a code 33 again? why is this.. Jesus it was a bad enough job i wouldnt want to do it again!:confused1:
have you reset the codes on your ecu? could just be showing the old code, take the battery off for a few hours, then check again mate....
could be a wiring issue then? was the sensor you put in new or a know good one? all the connections clean? (i'm sure you would've checked that tho matey)
you haven't got the plug mixed up with the dett sensor plug have you? they are both the same (just clutching at straws here!)
