non turbo rear wheel bearings
anybody replaced them? is it easy enough to do and where is the cheapest place to get them as it scared the shit out of me from courtesy nissan @ $240 each plus shipping plus import duty!!!!
Pattern ones are available if you wish Gaz for about £100.They are pretty straight forward to fit,no pressing as it comes assembled in a carrier hence the price !!
thanks guys. the rear wheel bearings have been mentioned the last couple of years on mot. just wanting to be ahead of the game just incase they fail this year.
looks like whatever i do its a couple of hundred quid to fix..... i have bought two complete engines for less!!!
  • 3 weeks later...
am i right in assuming the na and tt bearings are different due to the hicas system on the tt?
Im not sure if its due to the hicas,maybe the driveshafts set them apart as the diffs are different also,but the bearings are listed na or tt.
Thanks jimmer thats what i thought, was going to buy some but the seller tried to tell me the bearings are the same..... they were bought for a tt but obviousy mine is a non turbo.
What a cock trying to palm you off with stuff that dont fit :mad2: From what ive researched it seems na bearings are more expensive than tt,s.Probaly because they are rarer i should imagine.
aint it just. well i just said thank you for the information as i couldnt be bother to argue with them.
but if anybody wants some cheap tt wheel bearings then
ebay Item number: 220752989408
I got both my TT rear bearings from Mr F.
If i remember correctly, i dont think i paid much more than £250 for both.
They aint hard to change either. Just pop the driveshaft out, undo the 4 M12 bolts and the bearing and carrier will some out (might need some persuasion though)
