Bleeding brakes
Hey all, anyone know the ordering in which to bleeding brakes including the abs pump?
Also, is there 2 pumps or just the one in the boot?
This is how i did it.
Uncover the ABS pump in the boot on the drivers side wheel arch cover.
Jack car up on all 4 corners
Take wheels off
Take some air bubble tubing (for a fish tank) and place it over the bleed nipple on all 4 calipers, and both bleed nipples on the ABS unit.
Having someone pump the brakes while you top up the brake fluid helps, use a empty container and feed the excess fluid from the air bubble tubing, with the air bubble tubing, you will clearly see the air, once the tube is pumping air free fluid, do the nipple up.
I bleed them in this order.
Bleed the ABS
Bleed the rear brakes
Bleed the front brakes
Bleed the ABS again
Check, if all is ok, the peddle should stiffen up every time. if there is still air in the system, it will feel soft and spongy. ive heard rumors that you should do it, passenger side, drivers side fronts, the rear drivers, rear passenger side, then the ABS unit. but when i did that i found that i still had plenty of air in the system.
