Boost controller
Hey guys is this any good. http://cgi.ebay.co.uk/NEW-Gizzmo-IBC-Electronic-Boost-Controller-Ltd-Edition-/220740315358?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item336525e8de
I dont want anything fancy and i dont want to spend a fortune on one either
Because all i want if for it to hold boost at about 1.1bar about 16psi i think?
it has 4 settings but imo whats the point i only want one and thats full power :lol:
so it sounds good to me and easy to fit by the sounds of it. what do you think? i can then get mr Dixon to map my car hopfully
why?
Only messing, looks ok! only 2 wires to connect!! but quite a few pipes to connect!! basic but functional!! why not spend a little more and go for a proven one? I understand you have baby on the way and money is not abundant ect, so go for it and if its crap get your money back if you hate it
Yeah. its on a 7 sec car so cannot be that bad i surpose on my 13sec car :lol:
I doubt i will even have it on show, just set it up and hide it away, are they easy to fit?
Good idea, my Apexi was ok to fit, but lots of wires needed splicing into the loom, and the pipe work was a little fiddly, you need to run the pipes from both the turbos/waste gate/actuator to the solinoid and then back to the control unit, but if youve done the plenum bypass it will be a doddle for you!!
there are lots of wires on the apexi due to the info it gives on the screen, but really not needed if your hiding it away!!:cool3:
Edited by daZvert
mate of mines running 300+bh using that ebc in his 14a....its reliable and has been for over 2 years
i run a greddy profec b spec II.... ;)
Good idea, my Apexi was ok to fit, but lots of wires needed splicing into the loom, and the pipe work was a little fiddly, you need to run the pipes from both the turbos to the solinoid and then back to the control unit, but if youve done the plenum bypass it will be a doddle for you!!
Cool so 2 wires, guessing live and earth lol!!! and just the boost pipe to fit. is it the same pipe where you out the mig tips in and there is the solinoid and what does it look like?
Is there a how to?
Good to know. is it easy to fit and use do you know?
my mate managed it and iv fitted mine, there all the same anyway, in a TT you need a T peice to connect both actuator vac pipes to one vac pipe that goes back to the solenoid (if im remembering rightly)
Nowt wrong with the Gizmo mate-ask Mr Smithy!:wink:
I/we fitted one to Boldy's car dead simples........
Cheers Mate I think i might be going for one of them at that price :batman:
