Creaking brakes
Whenever i push my brake pedal down i get a creeking noise comming from the outside of the car, the brakes work o.k they just make a funny noise, could it be the cable? I dont even know if these things have brake cables or not seeing as ive only had it a few days. Also can anyone beat my fuel bill £86 in 3 days.
Hi matey the brake problem is most likely down to a clean up in the caliper area. Rmove the wheel and the the two retainer pins and clip holding the pads in, then remove the pads (may need to push them back a little) and give the whole area a clean with brake cleaner and remove all the crudy build up, also take the shims off the back of the pads clean and re-grease with a dab of copper slip then put back (if pads ok)also check that the pistons are all free when pushing back if not they will need releasing. Jeff TT
I had the same problem and replacing all the rubber bushes for the urethane ones cured it for me
Paul
