Got code 21, Where do i start?
checked flash codes today and it came back with code 21 (Ignition signal circuit), would this explain my revs hunting and an intermitant stutter?
where the hell do i start to try and sort this?
It is booked in at zedworld on wednesday for a conzult and a general lookover.
Code 21 is a non starter code, so as your is running is on old code that will not have any bearing on your present issue.
Revs hunting can be too low base idle, tps issues, throttle balance, temp sensor etc. bad connection are as likely a cuprit as any too, if the code is bothering you then clear it by disconnecting the battery for an hour or so.
Failing that will sort it for you Wednesday.
Jeff TT
chears Jeff, i'm looking foreward to it.
Wish we could come down with you Ste! Hope you're ok, not seen you since the summer!
yeah i'm getting buy thanks jane. hope the startlets going well. you up for the scotch corner meet?
Cool, glad you're ok
Yeah we'll probs come along to the meet up, if I can remember when it is lol!
The Glanza - Marc drives it mostly. I am not keen on the auto box and to be honest I walk or cycle to work and tend to use the Puma when I'm driving
