Engine Flush
I have been working on the bodywork of my 300tt for some time now,:yawn: and each week I run the engine up until warm. I have sorted the tick over problems and set the timing etc' but I am experiencing a regular tapping noise.:hammer: It does not seem tinny enough to be a tappet (not that I would know anyway:sad:)and not clunky enough to be top or bottom ends. My question is, should I consider using an engine flush, and if so, what would you recommend? also, how do I use it to get the best results?
Thanks in advance.
Sounds like a hydraulic lifter sticking matey, get some "wynns hydraulic lifter treatment" from most car parts shop. Should quieten the little bugger down.
Alz.
Edited by AlanZ
You might need to give it a run too, build up some oil pressure and get it flowing...
Thanks AlanZ and Tudor... I will take up your suggestions this weekend and let you know how it goes.:bow:
