- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Ok,
problem has changed over the past 3 months....
started with running a bit rough on start up, then driving down the motor-way, all of a sudden car would run really rough in 5th under load, then in any gear, had to pull off motorway, turn off car and restart OK. (but it wouldn't happen all the time)
So I got another set of coil packs, fixed the rough at start but still had the same problem on motorway.
bought a new PTU, fitted that.... no difference... Cleaned the contacts for the CAS and that seemed to make it a bit better......
replaced the air filter and cleaned the contacts, cleaned the contacts for the TPS and any other I could get my hands on still the same...
So now seems to run fine, starts and warms up OK, on motorway under load seems to boost fine but again problems in 5th under any load, car hesitates.
i've put in on the free version of conzult, no error codes but strange readings from IACV (way too high) & O2 readings (up and down at idle, 0.1 to 0.8) ...
I did a 40 mile trip and them took these readings on the driveway... any help & advice much appreciated.
