Water pump
Hi,
Is it a big job to swap the water pump, I take its ran off the cam belt?
Thanks Mark
Spot on cheers bud:-)
Mark
Hi,
Thanks Mark
Change the cambelt when your in there as a leaking pump will have been pouring scalding water over the belt.
Jeff tt
And make sure you only buy a genuine Nissan item, not a pattern version!
JeffTT posted a thread soe time back comparing an aftermarket one with the OEM one - the impeller on the OEM one was much bigger. It's essential for efficient cooling on these engines!!
Richard:cool3:
Cheers Richard spot on.
Mark
