February 16, 201114 yr Uk has an oil cooler, external pump and heat sensors to run it, apart from that they are both the same. A UK diff will run quite happily without the cooler attached and you just need to blank off the pipes on the top of it.
February 16, 201114 yr Author I have a import shell and running gear (diff) i need to take my wiring loom off my uk car on to the imported car. Can i leave out the loam that go,s to the uk diff cus i am going to leave the import diff on?
February 16, 201114 yr The only plugs on the diff you need to worry about are the ABS sensors on each side. The UK loom has these connections so you don't need to change over to the jdm one. Just tuck the spare connectors away or blank them off.
Whats the difference between a uk and import diff?
