Which one ?
I am looking to do an engine oil and tranny oil change on my TTZX and wondered what your thoughts are on the oils below my zed has covered 68k, which would be best suited to my car, Im not looking to race (maybe the odd spurt) I got the list from OPIE oils
Engine Oil
Silkolene PRO S 5W-30 Ester Synthetic Oil For High Performance Engines
REDLINE High Performance Synthetic Motor Oil 5w-30
Amsoil Synthetic Engine Oil (ASL) 5w-30
Castrol EDGE 5W-30 fully synthetic engine oil
Tranny Oil
Amsoil Synthetic Automatic Transmission Fluid ATF
REDLINE D4 Synthetic Automatic Transmission Fluid
Fuchs TITAN ATF 5000 SL Fully Synthetic, Heavy Duty ATF
Would apprecialte peoples thoughts on which one I should choose and why
I know its regularly bee changed with 10/40 semi synthetic, I think it was magnatec, and you know how well it runs on that!
I always asumed a 5/30 was more for the winter months when the oil needs to be thinner due to the cold???
if it was me id go 10/40 again
as for the auto fluid there pretty much the same so doesnt really matter.
Hi Craig,
Was ment to ask this yesterday, When I was driving back from reading the steering wheel was of centre but was driving fine so didnt think anything of it, but whenever I have to take a sharp right turn it sounds as tho something on the front passenger side is wobleing. could it be a bush or something?
No idea chap not something I've noticed or mike mentioned?
Hi Craig,
I know this sounds stupid BUT just check the wheel nuts, now our cars are getting older strange thigs are begining to happen.
Quite a few here including myself have had wheel nuts loosen due to the threads streaching on the stud.
99% it wont be this but it does occure.
Allan
i use silkolene pro s 10w 50 for me engine and oilman sorted some silkolene for me to do the diff and gearbox will have a look later see what it was.
dan.:biggrin:
i only ever use Millers CSS fully synthetic in my engine i know others rate it highly as well
For a twin turbo 300zx a "30" rated oil is just too thin considering the temperatures encountered under the bonnet!
Stick with a minimum "40" viscocity mate.
Nissan recommends a 10w40 semi synthetic but personally I'd pick a fully synthetic just because technology has moved on since 1990! Any decent 5w40 synthetic oil will be fine - I currently use Shell Helix Ultra. The 5w30 oils are more for todays modern engines.
Remember the "w" is just a reflection of the oil's ability to circulate from cold and not an indication of oil viscocity once fully warm - ie 0w40, 5w40 and 10w40 are exactly the same once up to full temp!
Richard:chef:
Great answer. Set out nicely and based on facts. And will cover the vast majority of the cars/engines on this forum.
Brand is of little importance so long as its a known quality brand.
Different people will have different brand preferences
Allan
Hi gruntpa64,
Never thought of checking this, ill look this weekend, still driving round in my passat for now.
I can only repeat what I have read while deciding on oil for my N/A, but I did see mention that its not a good idea to use 5w in TT's ....
