REVS problem !!
Today I get a problem with my z. that I going on high speed and that I braking hard my engine going off . what this can be? boost leak or what?
are you on standard air filter?
No mate I got HKS one.I dont understand thanI reving just a little bit my revs goes up and then down to 400. and beck to normal. and branking hard revs goes to 0 revs and engine is off than
Is you talking in text speak or what??????? are you a teenager????
The issue you have is most likely caused by basic engine set up or a failed auxillary air valve.
Basic tick over speed is perhaps too low and the aav struggling to recover in time when the throttle is shut quickly.
With the yellow pug disconnected from the aav (back of engine battery side) see what the tickover speed is and if required raise it slightly by adjusting the base idle screw on the side of the same uinit (facing the battery) anti-clock wise is to raise the revs and clock wise to lower th base idle speed, then plug the yellow pug back in and it should settle down, if the issue is still there its likely the aav is faulty.
Jeff TT
Jeff TT
Thanks for all information I will try to have a look today. I am sorry English isn't my first language sorry about my writing.
No worries, only playing with you, always impressed with anyone who can speak/ write in more than one language we are generally quite lazy in this country about learing other languages.
Jeff TT
Jeff TT
Wot? ya saying me lzy?
(did you pick up on what i did there? ;))
Yeh sure did :yes: you thread highjacker you:offtopic:
Jeff
Jeff
hmm how can i comment back and still keep it on topic..... ooh i know.
Jeff can help you out, hes good at this sort of thing. :tongue_smilie:
Jeff TT
I can't find yellow plug to disconnect from aav. It is a hard visible?
passenger side of engine back of plenum near baulkhead.
left of the battery
Marked in the square on the pic, the FICD is below it
Edited by groover
ohh this is amazing. Thanks for GROOVER. I will try to fix it.
does anyone had this the same problem before?
