need help with idle problems....
Hi, I am having idle problems whenever I go to slow down and stop the car. The car keeps trying to cut out and sometimes does. Its ok when first started but soon starts to play up :huh:. Has anyone got any idea on what the prob can be and how to sort it out...? Cheers Jay
Its a 91 tt jap import manual
Boost leak would be my first guess, check for leaks.
Check the yellow temperature sender on the top alloy water pipe , mine was very green and corroded and i was getting stalling problems when braking , being so corroded i think it was telling the ECU the wrong temp reading , i.e it was saying it was still cold even though the car was nearly up to temperature and was slightly overfueling , i cleaned the terminals and connectors and it cured it .
Hope it,s something as simple as that .
cheers guys i'll look into them this weekend, much appreciated
  • 5 months later...
hi,just read your problem,i have the same on my 91 jap swb.did you sort it?cheers psnot seen your zx around im in margate.
