Power steering fluid everywhere! thoughts please
should there be clamp on this hose?
Edited by andyb
wromg links
arghh! novice moment- wrong links.
The hose needs a clamp, doesn't look like it has had one for a while tho, not sure if it's above the other pics, could be the source of your leak, but only a guess, and yep, rusty pipes indeed mate :(
I mean in situ on the car, if that pipe is higher than the rest of the stuff in the other pictures, could be the source of your leak (hope that makes sense mate! If not, someone will explain better soon...)
cheers, the hose with clamp missing is lower down than the pump ( what I beleive is the pump anyway) so may explain the leak. But the rsuty pipes I think are attached to one of the oil coolers at the front. The rusty pipes may have nothing to do with Power steering on closer look but defo power sterring fluid leak and fluid is also higher up on the rusty pipes - well all over the pace really!
