N/A pump with TT pulley?
Hi all another question.
Im sure i see a thread on how to make an N/A pump fit a TT engine using the TT lightened pulley??
Am i right in thinking the TT pulley will not sit in the right location?
I havve the N/A bracket im just under the impression the pulleys wont align right?
Dan
no they dont and it was my modification which aligned it to fit. search for thread titled. full unothodox pulley set posted by myself...
Did you fit the N/A back holding bracket as well mate, or leave the TT one on?
Usually it's a case of using the N/A bracket with a little bit of metal shaved off.
smithy
Im running NA Pump with TT Pulley. no modifications.
Have to make sure you use the NA Pump bracket, rather than the TT pump bracket.
So am i thinking right if i change the TT bracket to a N/A and fit the TT pump ill have no issues or modifications to do?
Cheers Dan
Close mate :-)
If you want an N/A pump in a TT motor then you use the N/A bracket.
See no reason why you can't fit the TT pulley to this.
If you use a TT pump in a TT then you use the TT bracket and you can if you wish take out the fins if deleting the hicas etc.
cheers
smithy
My issue was fitting a tt unorthodox pulley to a non turbo pump hence I did not have brackets to compare them.
But did you fit the N/A bracket to the BACK of the pump mate, it secures it to the block?
smithy
Sorry whats the benefit of doinhg this???
Clean(er) way of removing the un-needed bits when deleting hicas...
smithy
Mine is a non turbo . Swapped for another na pump but fitted a full tt unorthodox pulley set to it.
