9.5 et25 on the front
Hi,
Im wondering if anyone has fitted 9.5 at et25 on the fronts of there cars if so have you had any problems??
Cheers Dan
I even got the similar question, is 1)j et 10 will fit to zx, Because one guy is selling his rota wheels from skylie r33, 10j all around with stretch tyres, does wil fit?
jimmys works out at et18 on the front with a 2mm spacer. I haven't seen him on here for a while now.
I have 9.5 on the front but I would have to check the offset for you
size is 9.5x17xET+24
Son 9.5xET+25 would not be a problem
Allan
Edited by gruntpa64
oh thats great news im just worried about the wheel hitting the chassis on lock but if you have it already wahoooo :).
Im hoping it dosent rub? Im going for 18s with a 30 profile tyre can you see any chances of it rubbing as the wheel will be a bit bigger?
Thanks for your help
Hi gruntpa i just looked at your car spec in your ride section and it says a 9 on the front is that a error in typing :sweatdrop:
according to this http://www.1010tires.com/wheeloffsetcalculator.asp you'll be fine compared to mine. You'll have 8mm more internal clearance compared to my 19x10.5 et20
Wow jaffa you have some serious girth under your arches haha
Cheers for your help so as long as the wheels fit over my brakes im in the clear :clap:
