guys , help, i bought a HID kit removed my existing high beam bulb and compared the two, oh dear .it appears the nissan original has a spring built into the body of it anyone come across that before, im now at a loss as to what type of HID kit to buy, i have pictures but cant attach them to this site
The high beam bulb is a H1 but it,s in a seperate holder that clips into the light , most use hid for the low beam as high beam is usually very good .
gents, i now want to improve the high level beam, as you would expect when swapping from dip beam to high the effect is dramatic, white light to yellow, not a good mix, can anybody advise what i should be installing???, should i simply change the type and output of the bulb without going to HID if so, thoughts on Wattage , make , type and supplier etc etc, can i run two bulbs from 1 HID ballast ???? if so where can i get the necessary adaptors and necessary bulbs, the units i put onto the dip were 6000 white lights, it also seems that the low beam goes out when switching to high beam , is this normal ???,
thanks
If you ground one side of the dip beams they will stay on with the high beams when switched. I did fit some super white H1 bulbs 5K and they looked better,
You can only run one bulb per ballast.
Take your pick, but try and stick with 55w or you are adding extra load to the system
http://shop.ebay.co.uk/i.html?_nkw=H1+super+white&_sacat=0&_dmpt=UK_CarsParts_Vehicles_CarParts_SM&_odkw=H1+super+bright&_osacat=0&_trksid=p3286.c0.m270.l1313
thankyou Groover, any idea where i can get the adaptors from ??????
What adaptors? if you mean for the H1, you already have them lol The H1 bulb is plugged into an adaptor plate with the prongs on the back that the wires are plugged into.
Bit fiddly to get the clip released that holds the bulb/adaptor in the light, but nothing major.
oh, thanks for that, when i looked at them they appeared to be part of the bulb with no way of removing them.
