February 2, 200224 yr Has anyone out there ever changed the heater matrix?.. if so how do you get the dash out??? all of the necassary screws and fixings have been removed yet it will not release its self from the windscreen Doh! Also is the heater matrix repairable?
February 2, 200224 yr Heres a How to on removing the dash: http://www.twinturbo.net/ttnetfaq/FAQpages/dashboard.html Heres a how to on replacing the heater core without removing the dash(may have some helpful info): http://216.119.125.120/forum/tech/heater/heatercore.htm Not to sure if the heater core is repairable - if you put rad weld or something similar in the core it may leak somewhere else later on, due to age of the whole unit(plus I've never have any luck with rad weld type stuff and wouldnt want it going around my Zed's engine). I thing a heater core on its own is about £150 if I remember right(had mine done by SE-Nissan last year). Hope this helps. Trev
February 3, 200224 yr Get the car checked for earth leaks!!! When mine went the next three lasted six months in total. The cause of the problem was eventually found to be an earth leak. Stray currents, especially when the starter motor is turning over can cause electrolytic corrosion of the matrix. I found an article in a trade radiator magazine that reported destruction of radiator elements in less than a day in some circumstances.
