hi guys,want to renew grill mesh in my front bumper,how big a job is it to remove front bumper?any advice greatly recieved!!!:confused1:
The front bumber is not that hard to remove if not a little tedious its just a matter of getting to each screw as you have to reach up behind the lights from memory
me and a couple of mates had mine off and another on within an hr or so, there should also be some threads on it with a more detailed description.
Is it a standard bumper?
If so remove fog lights there is some bolts behind there, then remover nose panel & remove the ones either side on the bracket,
Then in each wheel arch along the line of the bumper there is 2 or 3 each side iirc these are the awkward ones! Good luck
I thought that with the renew mesh although it could just be stuff someone has bought and fitted :)
If it is a standard bumper then no need to remove it, just remove the airbox and the plastic cover just behind the bumper at the bottom and there is plenty of room.
Jeff TT
