ecu.s and stuff?
i noticed inthe back of me car when pulling it apart there r loads of ECU.s and a box with pipes coming out of it. It looks like something do with ABS? Any ideas. I want to take of the rear steer and if there is any crap i can take of like ECUs can i take them off?
If looks something like this then its is the ABS unit so leave well alone.
Jeff TT
cheers jeff i had a look at it last night and it said abs on it so i thought it was. But wat r all the ecu? They r every were?
ECU ? maybe Fuel Pump control module ?..is it a LWB or a SWB ?
In the boot area on the right hand side you have the following
Ariel timer module
Rear Speakers amplifier (UK spec only )
Light bulb failure module (behind rightbhand light cluster)
On the left hand side there are two relays
Jeff TT
lwb mate. But down by were the front seat belts r by the rear quarter ther r ecu.s there. Not sur what they r for.
Thats the Fuel pump ECU/Controller and If its a UK model then shock aborber control unit
Edited by Yowser
Ok the ecu on the drivers side by the seat belt is the main ABS module the other part with the pipes in was the ABS actuator pump.
The ecu`s on the passenger side is the fuel pump controller, a small relay attached to the frame of that is the interior light unit, and if a UK model a further small ecu is in the same area and is the adjustable rear shock absorber module.
Unfortunately for you non of it is removeable without loosing a vital system.
Jeff
thanks to all . At lease i now know. U learn more every day. Dont know a great deal about the zeds so it all helps
