Hicas warning lamp
I have just had the Hicas warning lamp appear on my 1990 uk tt manual i think i have a leak on the steering system as found red colour oil puddle under the car! has anybody got advice on common sights of leaks or indeed suffered the same problem? cheers
its a common fault on zeds unfortunately . check the hoses under the fluid pot . they tend to leak from the join between the rubber and metal . if that ends ok it will be the other end of the pipe for sure. common fault . jefftt at zedworld has these pipes made up .
if you do find the leak let me know as i had non leaking pipes to take off mine :) Light will come on due to low level of oil
