nismo cluster in a series 4
  • Replies 27
  • Views 1.2k
you'll probably find that you will need a boost sender to go with the boost gauge.
was the cluster that you took out factory fit?
Yeh,
The previous cluster was factory fitted, just checked the engine bay and the cant
see any pipes going to where the sender should be so it likely missing !
Anybody got a pic of the loom or where the sender is actually seated ?
Next question would be who's got a sender that they could sell me ?
the sender is normally sitting just to the left of the brake servo with a vac pipe going to it, leading from the balance bar and has a 3 wired plug, much like a coil pack or O2 sensor plug connected to it. you maybe lucky and find said plug just sitting there ready to be connected to it ;)
The s4 didnt have a boost guage so i very much doubt it will have all the wireing for it etc??
Heres a pic of the new nismo cluster i bought from the states !
Set me back £160, but was worth it cos the series 4 clocks differ and
I couldn't get a hold of any in the UK that would work !
Only two faults that i could detect with it so far, one is the boost guage
dont work and the second is the seatbelt light stays on all the time but
i think i'll just pull the bulb on that one !
the sender is normally sitting just to the left of the brake servo with a vac pipe going to it, leading from the balance bar and has a 3 wired plug, much like a coil pack or o2 sensor plug connected to it. You maybe lucky and find said plug just sitting there ready to be connected to it ;)
wheres the best place to check for the wiring and wheres the sender usually seated ?
hellooooooooooooo
doesn't look like a cruise one, though i could be wrong, thought cruise was flat, and didn't have a socket like a O2 sensor
pic of a red cross on here, could it be that im an out cast and not in the sub'd elite anymore? :D
mind you, even your sig has gone jaykay
Thats great news !
on the other hand there goes my idea to add cruise to my zed :no:
meh cruise is for lazy people lol:innocent:
