protoj · 8 hours ago 8 hr
Two questions really lol,can anyone shed some light on whether the nissan 300c(cedric) gearbox is the same as the z31 300zx gearbox,or simply will the 'box from that old v6 fit the z32 v6 motor?Just Ive been offered a cheap deal on one of these old boxes for my z32
