shock absorbers testing?
is there anyway of testing your shocks on the car to see if they have come to the end of there life? or do i have to take them all off? :helpsmilie:
You could always try the old push test. Just put some weight (i.e. Your hand) on the corner you want test and remove it. If the shocks are good it should come straight back and settle. If it keeps bouncing for a little while then the shocks on it's way out. Not very scientific though.
You can also look for leaks around the shock.
cheers matey i will give it a go my handling seems a bit sloppy i thought the shocks might be going as it was 20 years old by now
