japspeed rad top fittings
Just fitted my japspeed rad, fitted fan surround but the bottom peice fouls on the air con compressor clutch wheel thing, so didnt fit that peice.Is this going to be a problem also had to cable tie top mounts as the brackets dont fit i know you can get a custom made panel for this but has any one made any top brackets thanks.
I have a toyo rad and mine fitted fine. Are you sure you have the bottom of the rad fitted in the rubber bungs??
Iim sure ive got it in the bottom bungs but its pissing down here will have a look when it stops raining .I think the japspeed rad is thicker than a koyo maybe thats why, japspeed is 56mm thick.
